The best way to lock two helmets onto the bike
Discussion in '5th Generation 1998-2001' started by Gryphon, May 3, 2008.
  1. Gryphon
    Gryphon New Member
    Alexandria, VA
    What's the best way to secure two helmets on the bike. I've tried everything from placing the helmets on the rear grab bars and trying to lock tem together with a bike lock, but the seat want shut, too looking at a Denis Kirk catalog for a universal helmet lock to put on the other side of the bike. You'd thought Honda would've places the hooks under the locking seat?
  2. KC-10 FE
    KC-10 FE New Member
  3. Gryphon
    Gryphon New Member
    Alexandria, VA
    But how do I secure that to the bike. Do I replace the two pins that are already there? Then buy the two little locks that keeps those extenders from coming off?
    Is there anyway to secure them while riding? cause those will also add length then the helmets will be rubbing the tire/chain/ground?
  4. KC-10 FE
    KC-10 FE New Member
    You slide the blade thru the helmet rings just as shown but it's long enough to go thru 2 of them. The bottom helmet goes upside down & the top right side up. It works, I've used one but I don't have it anymore to take a photo. Just be careful you don't scratch the helmets.
    KC-10 FE out...
    :plane: :usa2:
  5. Gryphon
    Gryphon New Member
    Alexandria, VA
    I understand know. OK thanks. LOL
  6. STEVE MANKIN
    STEVE MANKIN New Member
    ft. myers fl
    runa cable to the helmet lock and through the helmet rings........areostitch sells em cheap....nice also if you have a helmet with no rings
  7. Gryphon
    Gryphon New Member
    Alexandria, VA
    That's me
    One of my helmets did not come with D-rings due to it being a quick disconnect helmet. Will the seat still close using this cable?
  8. Vlad Impaler
    Vlad Impaler New Member
    Indianapolis, Indiana
    I've run a beefy Kyptonite cable lock through the chin guards on two full face helmets before. No D ring required.
  9. STEVE MANKIN
    ft. myers fl
    run the loops of the cable...they come w/loops on both ends...... through what you want to lock.....and lock both loops in the helmet lock.....nice for jackets too.no need for helmet rings..and seat stays on....i got mine for 6bucks..cheap insurance.
  10. pm_wizard
    pm_wizard New Member
    Toronto, Canada
    I just use a retractable ski/snowboard cable lock, and run it through the visor opening on the helmets and around the frame. When i am done it goes back in my tank bag. If someone wants your helmet badly enough to be able to cut through that, then they will probbaly do enough other damage anyways.
    John
  11. nitronorth
    nitronorth New Member
    Kamloops, BC
    I got a small antitheft cable , about 8 inches with loops on both ends..it was the helmet lock thing from the vstrom thing..only good thing about that bike..but anyway..Nothing to carry, I always leave it hooked on the stock helmet lock and its long enough to hook 2 helmets thru it to the lock....simple.I do however carry a light duty cable lock for tieing my jacket to the bike when I want to go exploring.
