The 1$ Solution to Installing a Center Stand
Discussion in '5th Generation 1998-2001' started by nwrider, Jul 21, 2008.
  1. nwrider
    nwrider New Member
    The 1$ Solution to Installing a Center Stand w/o removing exhaust
    I just received my EBay center stand complete with the rear shock mount bracket. First, both bolts holding the center stand to the rear shock mount are standard right hand threads. Second, there's ample room to install a flanged hex head 10 X 50 mm bolt from the back side of the mount. As the bolt protrudes through the center stand start threading a 10mm nyloc nut on the end. There's room for the nut to be installed behind the exhaust header. And, the best part, is it costs less than a dollar and you don't have to remove anything.:strong:
