Technical Question
Discussion in 'General VFR Discussions' started by jeff8478, Apr 15, 2009.
  1. jeff8478
    jeff8478 New Member
    I've heard that if you put extra air in your tires, the bike will go faster. Is this true? Should the air be cold or hot?
    :confused:
  2. Carnage
    Carnage New Member
    Terrell, TX
    I would not advise this since there will be less contact patch on the ground.
  3. Longerfellow
    Longerfellow New Member
    Pollock Pines, CA
    Performance tip:
    Run the air on the OUTSIDE of the tire. Less unsprung weight.
  4. MrDen
    MrDen New Member
    Maricopa, AZ
    It depends on whether you use standard motorcycle air or high-speed rated air. Also, be very careful that you don't confuse rear tire air with front tire air, or you will create a very wobblish situation.
  5. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Wait until its really cold outside, then inflate your tires with as much air in them as possible. Wait till it gets hot outside and drive your bike as hard as you. That loud explosion is you breaking the sound barrier... It'll be super fast!!!:thumbsup:
  6. Knife
    Knife Member
    Downingtown, PA 19335
    Helium. That's the answer.
  7. eddie cap
    eddie cap New Member
    Valley Forge, Pa
    Propane or nitrogen,not sure but its one of them ! If it turns out to be propane
    make sure not to "lite up" when checking tire pressure.
  8. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    Does anyone know how to fill a tire with Slick50? Is there a special valve I need to attach to the bottle? :biggrin:
    Regards,
    Rollin
  9. Marley Davidson
    Marley Davidson New Member
    Matosinhos, Oporto
    Its helium, this gas is lighter than o2 so the tyres will also be lighter, but i think you will not feel your bike faster...
  10. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Yes air in the tires will make you go faster. More air, faster you go. Just use summer air now.
  11. porcupine73
    porcupine73 New Member
    Also add a bit of synthetic silicone based air wetter. Slick 50 can work but it might not be compatible with rubber.
  12. Ghost
    Ghost New Member
    Kernersville, NC
    Answer is:
    Yes. more air in the tire, means a smaller contact point of the tire to the pavement. Less contact area, means less friction. Less friction, means the bike moves quicker, and responds quicker.
    Cold air is better. Cold air wont allow the rubber in the tire to stretch. flexing rubber in the tire, will give a better feel to the ride, and absorbe more "bumps", however, it does increase the surface area, and we already said that more surface area, increases friction.
    Dont believe me? deflate your tire, front or back to about 11 psi. you tell me how it handles.
  13. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Ghost:
    You have to admit, this seems like a troll question.
    The poster gave us little information. What does he mean by "faster" 170 instead of 150?. What is meant by "extra air" 80 psi each tire?.
    Let me bust out my anti-troll tool! :tclaw:
    BZ
  14. porcupine73
    I found this article interesting about friction, contact patch, etc: Friction (and contact patch size)
    Maybe the thinking is more air pressure makes the circumference increase a bit so the top gear limited speed might be higher?
  15. supertex
    supertex New Member
    I have heard that in cages, thinner tires and over inflation increases MPG.
  16. nvoges
    nvoges New Member
    Columbus, OH
    I'd use Hydrogen as it's less dense than Helium. They used to use it in Blimps, but I think they ran out of it one time and decided not to use it. Hmm.....I wonder why????
  17. porcupine73
    Just don't hit any sharp bumps with the hydrogen in there.
  18. Longerfellow
    Pollock Pines, CA
    "I don't exactly know what happened officer. We was just ridin', suddenly he farted and flew off the road!"
  19. porcupine73
  20. deepdish
    deepdish Banned
    :eek: yes i heard gp bikes run 85 front 90 rear..:rolleyes:
