Anybody ever switched their speedo from miles to kilometers or vice versa? The analog gauges show both so it is no issue but the digital gauges don't. Their must be a switch to select one or the other. But then again that would just make sense. I just read a post that said you could toggle back and forth on the 2004 VFR so perhaps the 2002 is the same.
You just press and hold the reset button, the left one if I remember right. Haven't read up yet on how to go from Fahrenheit to Celsius though lol.
Woobie is correct. Press and hold the Select button on the left and it will switch the speedo/odometer between US and metric units. If I remember correctly, you CANNOT switch the temperature display between units.
