switches
Discussion in 'Mechanics Garage' started by strangeintp, May 22, 2008.
  1. strangeintp
    strangeintp New Member
    This may be more of a general motorcycle question, but I'll throw it out there:
    I'm missing the handlebar electrical controls (switches and switch housings) on my '86 VFR700 project. Why is it so doggone hard to find aftermarket switches? I don't want to spend the exorbitant amounts for the OEM switches. Besides, the OEM switch is big and bulky.
    Electrosport sells combination turn signal/horn/HILO/kill assemblies, but I can't seem to find start/run switch assemblies. Does anybody know where I can get one?
  2. drewl
    drewl Insider
    Virginia Beach, Va
    check out salvage yards on the internet. a lot of them have parts request forms you can fill out. you might get lucky.
  3. VT Viffer
    VT Viffer New Member
    South Carolina
    Just search eBay until one you like comes along. They all work the same, regardless of brand or make.
    Just check that the bar diameter is the same as the bars on your VFR.
  4. strangeintp
    Thanks... you're right, there are plenty of switches, but I just realized a problem: the business end of the throttle pipe is also housed in the right handlebar switch assembly. So I have to either keep the old (non-functional) assembly on there just for the throttle and add an additional start switch assembly, or change out the handlebar throttle mechanism.
    Anyone have any suggestions?
  5. VT Viffer
    South Carolina
    That's going to be the case with most right switch assemblies. Probably just want to buy a stock one or better yet, disassemble the switch you have and clean it up so it works.
    I have made several "inop" switches work like new again with a little work and some contact cleaner.
