"stuck" turn signal indicator
Discussion in '3rd & 4th Generation 1990-1997' started by bakayara, Oct 3, 2009.
  1. bakayara
    bakayara New Member
    Dallas(-ish), TX
    Question... Just purchased a 97 VR750 and the dash indicator for the right turn signal is always on... the bulbs seem OK when flasher used, what does this indicate?
  2. crustyrider
    crustyrider New Member
    North Country, New York
    you may have a bulb installed "wrong" not sure what the later model bikes have for dash bulbs but thats what it could possibly be....
  3. NorcalBoy
    Somehow the indicator bulb circuit is still 12v hot, even though the switch is off at the switchgear. I could not find a wiring schematic in the wiki, so I'm not sure how the circuit is completed to light the bulb on the dash. My suspicion is in the wiring for that circuit.
  4. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
    It sounds like it is shorted to the marker light power. As usual, start with the switch and start checking the connectors. Happy hunting.
  5. squirrelman
    Stock or aftermarket signals??
    Aftermarket Taiwan-made signals are very low quality, poor soldering, worst materials, can easily short or cross wires.
  6. bakayara
    bakayara New Member
    Dallas(-ish), TX
    Near as I can tell, the bike is totally stock
  7. RVFR
    so what I'm hearing is the turns signals work like they are suppose to? and the indicator dash bulb stays on, or does it flash when you use the signals? check both bulbs, front one could be in wrong as it's also doubles as a running light. Has this bike seen a lot of wet conditions? When I took off the tail faring once and forget to plug in the wire harness to the taillight the dash signal would stay on. so this tells me something is not connected or broke or out or all of the later
  8. v4pwr
    v4pwr New Member
    cleveland, ohio
    i'm agreeing w/ crustyrider. looked in wiring diagram and if the bulb and/ or socket is bad it will illuminate the signal indicator. basically what is happening is if its a bulb or socket shorting the "park" filament of the bulb will feed power back through yhe turn signal wire which will illumate the indicator, like u have. hope it helps
  9. squirrelman
    unplug front and rear signals separately to locate the bad socket.....dash light will go out.
  10. bakayara
    bakayara New Member
    Dallas(-ish), TX
    K, thanx.. I'll be back home tomorrow (stupid job, gets in the way of riding) and check it then
  11. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    If any of the bulbs are supposed to be a dual filament (2 contacts on the bottom) and somebody has put in a single filament bulb (one contact), it could cause the problem, as it could short the two wiring contacts together when the bulb is inserted.
    I have no idea if VFR's use dual filament bulbs, but I have seen the same sort of problem on various automobiles.
  12. bakayara
    bakayara New Member
    Dallas(-ish), TX
    Back...
    (had to go up to New York for some legal stuff)
    Interestingly, took it out for first night ride night before yesterday and noticed that the right side dash lights were out (Gas/Temp and half the Tach) When replaced the bulbs they don't light, but the 'stuck' turn signal light dims way down... some electrical issue there to track down *sigh*
    First I'll have to deal with the new issue from last night, but since it's unrelated and I want a couple of opinions, I'll start a new thread... ;)
  13. VT Viffer
    VT Viffer New Member
    South Carolina
    The front turn signals in the 1994-97 bikes double as running lights. They require a dual filament bulb (1157, IIRC).
    If an 1156 single filament bulb is forced in, it will still blink as normal, but the dash indicator will be haywire.
    The dash illumination bulbs are identical to a 5W 194 bulb, but are actually less wattage (2.3W, IIRC), and are not nearly as easy to find. A 5W 194 will work fine, my concern would be with heat as you are more than doubling the wattage through that circuit.
    I think that you have some serious disassembly (side fairings, top fairing, etc) ahead of you (to get the dash out for inspection) if replacing the running lights does not fix your problem.
