stuck in SLC and need some help ASAP
Discussion in 'Mechanics Garage' started by Marine_VFR_RIDER, Jul 25, 2013.
  1. Marine_VFR_RIDER
    Marine_VFR_RIDER New Member
    Seattle, Washington, United States
    So I rode down from Seattle today to see my kids, (trucker) I ran down and my 2003 Non-ABS (100% stock) viffer ran like a dream... I pulled up to the house and shut the bike down walked inside the house to open the garage (litterlaly less than 5 min ) and when i tried starting the bike, there was nothing.. lights came on, fuel pump ran for a sec and before I could hit the starter button everything (and I mean everything) blinked out... so im figuring bad battery or bad fuse... so I charge the battery and check ALL the fuses and everything is fine... I have a wierd buzzing noise from behind the gauges all the time then the key is on, the starter relay buzzes and clicks when I hit the starter, power to the rear (lic plate light, and rear running light work fine, I have no headlights at all, the gauges flickker and display wired (bike key on not moving and the speed moves to sporattic speeds 2-19-5-33-5-and finally to 0 MPH, takes a few minutes for the gauges to show anything.
    Put battery on charger (out of the bike) and charged it to 100% and still no luck
    Disconnected the Main power line to the starter... no change
    Looks like I have no power to the headlights at all
    Tried hooking to a deep cycle truck battery (my ex wife has a power stroke diesel -- solve the prob if a bad battery) ... no change
    bike has 11500 miles
    recall done.... Unsure just got the bike last week
    acting like there is a HUGE drain on the battery... just spent 3 hours pulling off the plastics to find the two outer relays
    behind the gauges buzzing when the key is on ... continuously buzzing
    starter relay only buzzes when you hit the starter button
    If it will help I can shoot a video and youtube it and add the link here,
    any help you guys could send my way would be appriciated.... or atleast somewhere to start... I need to be back in Seattle on monday morning...
    Gunny
  2. derstuka
    San Diego, CA
    First thought that comes to mind is...have you had the wiring harness recall performed by Honda? I think they put a punch out on the VIN sticker when they do it. I know that can cause weird issues on early year 6th gens.
    If you can verify "for sure" it has been done, then you can rule that out. Based on your post, it sounds as though you are unsure. Again, check the VIN sticker for a punch out, and/or call Honda and ask them to check.
  3. derstuka
    San Diego, CA
    Welcome to the forum btw.
  4. VFR Love
    VFR Love New Member
    New York
    I called honda to ask if the recall was done on my new to me vfr. They were able to confirm that it was.
    Wish I could help more!
  5. TOE CUTTER
    From here all I got is to inspect the main ground connection, the buzz of relay's makes me think it is a possible ground issue.
  6. Scubalong
    If the recall has been done for sure then you need to check for Stator and RR. Your symtom point to the harness problem, I would check all the connector espcially at the head light. Un plug the head light and the high beam connector and try to start the bike. If the bike start then your hardness is faulty. Good luck and keep us posted.
  7. Scubalong
    BTW Thanks for your service Gunny :usa:
    Semper Fi:usa2:
    Ooooooooooh raaaaaaaaah
  8. hilbily
    hilbily New Member
    cant tell you if this is what you are experiencing but I saw this video the other day. Watch to the end to see the fix. Solution to my VFR Woes?!?! - YouTube
    I hope that this helps.
  9. Scubalong
    Hello Mr. Hilbily
    :welcome: to the nuts house :wave:
    Might want to introduce yourself :rolleyes: thanks for stopping by
  10. hilbily
    hilbily New Member
    I sure do need to do that. On the road now but will go to the introduction section when I get home. Fingers crossed I will pick up a new to me 2008 VFR middle of next week.
  11. Scubalong
    Safe travel and good luck with the purchase, 08 must be Drk silver....:rolleyes:
