Strange noise - need ideas...
Discussion in '1st & 2nd Generation 1983-1989' started by savedrider, May 19, 2008.
  1. savedrider
    savedrider New Member
    Southern California
    So for the past week or so I've been getting this noise when I take off from a stop. It's very low and sounds like a rubbing or grinding. I mostly feel it through the bike vs. hear it. It's from somewhere that rotates since it's not constant, but increases in frequency with acceleration. Once I'm into 2nd or 3rd gear I really can't hear/feel it anymore. At highway/freeway speeds I don't notice anything abnormal. Seems like I notice it more when leaning in a low speed turn.
    The brakes don't seem to be dragging. I just had the wheel off putting on a new rear tire and I adjusted my chain. Makes me wonder if the chain is too tight and I have a tight spot in it. Also wondering if the tranny could be on the way out. It's always had somewhat of a clunky engagement in 1st gear. Bike is getting aged (54,000 miles).
    So any brainstorming would really help. I'm getting squeamish about riding it in this condition. I might try loosening the chain a bit and see if it changes anything to start.
  2. CARMINE
    CARMINE New Member
    Italy
    (NAPLES) ITALY
    Hi.
    Check Oil (dot 4) In Clutch Reservoir (left Side).
    Lamps. Carmine
  3. VT Viffer
    VT Viffer New Member
    South Carolina
    CARMINE -
    What exactly does "Lamps" mean?
    Just wondering.
  4. derstuka
    San Diego, CA
    Sounds like it might have something to do with the clutch, or the tranny. The sound you mentioned reminds me of something that happened to me. The previous owner of my '87 FZR1000 overtightened the chain on a regular basis I found out, and this put extra pressure on the main axle drive bearing, thus causing it to literally explode, bending my main axle shaft, and damaging two of the gears....it sounded like something was grinding and dragging as I took off. Don't mean to scare ya....I am just sharing a shitty experience that I had.
  5. CARMINE
    CARMINE New Member
    Italy
    (NAPLES) ITALY
    Reply To Vt Viffer.
    You Know, When A Biker Meets Another Biker He Usually Flashes With High Beam Light, Just A Shot...and This Is The Way We European Bikers Say "hello" Or "see You Gain" In Our Slang ! I Think That This Expression Is Not "english Correct" But We Like It. It Comes From "lamp" And Suggests And Wishes A Ride Full Of Light And Pleasure. Maybe...too Romantic !!!
    Well, Lamps To All Vfr Guys !
  6. derstuka
    San Diego, CA
    I think that flashing your high beam to somebody else in the states will just piss them off...over here, you flash your lights to tell somebody to turn their brights off, or warn them of a cop maybe. We normally do the "motorcyclist wave" over here.
    I do like your saying though! LAMPS TO ALL VFR OWNERS! :wave:
  7. CARMINE
    CARMINE New Member
    Italy
    (NAPLES) ITALY
    OK...AND WHAT'S IS "motorcyclist wave" ?
    THEN, DEAR DERSTUKA, LAMPS TO ALL VFR OWNERS!
  8. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    I would recheck your chain adjustment. I had mine a bit too tight once and that is what it did in first.
  9. derstuka
    San Diego, CA
    Just that, a motorcyclist waving, hand gesturing, or nodding (if busy) to another motorcyclist. If I see some riders coming down the road, I just hold out my hand at waist level to say "hey."
  10. Pearl-93
    Pearl-93 New Member
    Elkridge, MD
    Interesting...
    I had similar issues if the chain was too loose.
    Tightened her up a bit/ changed clutch fluid and no more noises.
    I woudl assume the same to be true if it were too tight as well...
    Easy fix, just double check your chain adjustment (Loose or Tight)
  11. CARMINE
    CARMINE New Member
    Italy
    (NAPLES) ITALY
    Well, I Think I Will Do The Same As Derstuka...i Will Just Hold My Hand (the Left One !) To Say "hey"...
    Lamps To All Vfr Owners !
    Carmine
  12. Alaskan
    Alaskan Member
    Alaska
    Lamps to you too, Carmine.
  13. savedrider
    Southern California
    Well I have good news...it was the chain! That sucker did have a tight spot. I was in a hurry reinstalling my wheel and adjusting the chain last week. I always measure, but didn't really take the time to find the tightest spot.
    The chain was in need of a good cleaning and lube anyway. I ride daily and tend to neglect it mostly because it's a time consuming pain to clean and lube.
    The bike feels/rides so much better now! Smooth engagement and shifting. Having it too tight really took away from the performance. I'm glad it's fixed because I don't really feel like buying another bike right now. I like my VFR for the time being. It runs good and is paid for. :smile: :vtr2:
    LAMPS to you CARMINE!
  14. CARMINE
    CARMINE New Member
    Italy
    (NAPLES) ITALY
    Well, It Is Nice To See That Other Vfr Owners Adopted My "lamps" !
    Then, Lamps To You "savedriver" And "alaskan"...have A Nice Day With Your Vfr.
    I Feel Well "surrounded" By Your Kind Attitude And Friendship, But...what About Other European Vfr Guys ? Are They Sleeping...uhmmm
    Lamps To All Vfr Owners!
