Sticky throttle
Discussion in '3rd & 4th Generation 1990-1997' started by Bryan88, Oct 20, 2010.
  1. Bryan88
    South Africa
    Durban, South Africa
    Where is the best place to start troubleshooting a sticky throttle. Its not bad, just doesn't snap back which would make me feel a whole lot more confident. Any help would be appreciated, thanks.
  2. OTTOMAN
    OTTOMAN New Member
    Olympic Peninsula, Wa.
    I would recommend first determining if you feel it is a spring issue (return spring at throttle linkage on carb body may need replacement due to age, etc.) or a cable issue (dirty/dry/broken or binding). Do you have a cable lube tool and a silicone based lubricant?
  3. TOE CUTTER
    Remove the throttle tube , clean and lubricate the bar,tube and switch gear. Be sure the grip is not dragging on the switch gear and that the cables are routed correctly, cable routing will screw that up badly.
  4. Bryan88
    South Africa
    Thanks guys, will try that.
