sticker on top of ignition switch
Discussion in '6th Generation 2002-2013' started by signal, Jul 13, 2013.
  1. signal
    The sticker came off my ignition switch, the circular sticker that goes around it. It doesn't look like you can buy this separate, so I think I have to buy part 35106-MCW-L60. Does anyone know how difficult it would be to replace this part? It looks like its secured by a screw from the backside of it.
  2. stoshmonster
    stoshmonster New Member
    The ignition switch is secured to the underside of the top triple clamp with two 8mm bolts.
    To remove those two bolts requires a special tool called a T40 Torx bit. Just a heads-up Signal,those two bolts are slathered in high strength Loctite and are "FAT torqued" into that top triple clamp. They can be removed but they are difficult.
    ("FAT torqued" = Freakin'-A-Tight torqued)
  3. signal
    Thanks, but looking at the picture you posted with the arrow, wouldn't I want to remove the bolt directly above that one? The "cover" looks to be held on by two bolts. Are you saying I should remove the ignition switch, then remove the cover? I was hoping maybe there is a way to just remove the cover.
  4. stoshmonster
    Sorry my bad Signal,I've got it now you're replacing just the beauty cover and not the entire ignition switch. :redface:
    In that case yes all you have to do is remove the two 5mm bolts that hold the beauty cover on and remove it. Piece of cake.
  5. signal
    Thanks alot! I am going to try to do this, hopefully I can squeeze my hand in there without having to remove the front cowl
