Step One was easy.
Discussion in '5th Generation 1998-2001' started by Phatpapacap, May 28, 2009.
  1. Phatpapacap
    Phatpapacap New Member
    Broomfield, Colorado
    OK, after 10 mins and one beer I had the rectifier/regulator changed on my 1999 VFR. Mello Dude recommended that I also order a VFRness. When I pulled the RR off the bike, the plug with all the yellow wires going into it showed signs of overheating. So needless to say I'm ordering a VFRness from Wire My Bike. No, I don't have a manual for the bike so I'm ordering that too. My questions are; Will it hurt my bike to run it with the old harness until I get the VFRness? Should I attempt to replace the VFRness before I get a manual? And finally, Is the VFRness replacement a one beer job or should I break out the cooler?
  2. tcarroll
    tcarroll New Member
    Shelburne Falls, MA
    Service manuals are available here somewhere I downloaded one.
    The VFRness is an easy install. It doesn't replace your stock harness just compliments it.
    Be sure to use some terminal grease on the connections.
  3. tcarroll
    tcarroll New Member
    Shelburne Falls, MA
