Starter wouldn't disengage, burnt itself out
Discussion in '3rd & 4th Generation 1990-1997' started by 80sNight, Feb 27, 2012.
Tags:
  1. 80sNight
    80sNight New Member
    Taxachusetts
    I've been waiting to post about this until I had finished searching and troubleshooting myself. I've reached the point from which I cannot progress.
    backstory: About one week after successfully getting me to, around, and back to/from Nova Scotia (3k miles or so), my bike stopped starting. The starter motor would turn, I could hear pistons pumping, but no start. So, I winterized the bike; drained the carbs, put fuel stabilizer in the gas, topped off with a little fresh gas, flushed the coolant, and put her away.
    Took her out about 3 weeks ago, replaced the clutch and starter clutch, changed the oil and filter. Still no catching. It the starter motor would turn, piston would move, gas flowed, still no starting. Checked spark at all the terminals, seemed fine (don't know how to tell weak spark from good spark...). ICM readings were a little weird, registering 0 ohms resistance between every coil, but the voltmeter was also telling me that the battery had over 20vs; silly.
    Today, I put new plugs in, and spent some time cleaning up the accumulated grease. Unhooked the float charger, got her off the center stand (neutral switch doesn't work), pressed the starter button, and, oh how she wanted to start! I could hear it almost catching every cycle, but the it couldn't. I rolled the throttle on as I thumbed the starter again, and the engine spun up, but the starter motor wouldn't disengage. I let off the throttle and the engine stopped spinning. A small amount of smoke that I attributed to cleaner on the headers wafted up. I thumbed the starter... *click*. Thumb it again... *click*
    So, I fried my starter, didn't I? If so, does the oil filter really need to come out to get the starter motor out? If not, what else could it be?
  2. tinkerinWstuff
    I would start here. Sounds like something wasn't/isn't right with the starter clutch.
    starter motor might be OK.
  3. crustyrider
    crustyrider New Member
    North Country, New York
    sounds like it. might as well pull the starter ...take it an have it checked...
  4. 80sNight
    80sNight New Member
    Taxachusetts
    tink, I had the same thought originally. Then, my next though was, "oh, but I just put new spectro in..." I guess I could drain the spectro through a cheesecloth and put it back in when I'm done.:hangme: Yeah, I'm a cheap bastard. But, I guess next weekend is check out the starter clutch.
    Crusty, I hope you're wrong. Possible to remove the starter motor without removing the oil filter?
    Checked the relay, fuse is ok, didn't do any meter readings, out of light today
  5. tinkerinWstuff
    starter clutch is designed to keep the engine from spinning the starter motor. Even if the starter button is pressed while the engine is running, there is no grinding and you can't overspin the starter motor.
    In your case, you describe the starter as not being released and probably spun up at far too many RPM. Whether the starter motor is still good or not -it sounds, based on your described symptoms, like you probably have a problem with the starter clutch.
  6. 80sNight
    80sNight New Member
    Taxachusetts
    Beautiful logic. That makes so much sense. Alright, deffinitely have to check that out now. AND the starter; going to try the Honda service manual method of hooking the starter terminal direct to battery terminal.
    Thanks Tink!
  7. 80sNight
    80sNight New Member
    Taxachusetts
    well.
    I drained the oil, removed the starter clutch, checked that it spun cleanly in one direction, and not at all in the other. Bolted it back in, made sure it could spin freely (enough...), bolted the new starter in and... fried another one. I would have had a better time burning 50 actual dollars. I think it's time for a mechanic with a torque wrench, a garage and a deeper well of patience than I have
  8. tinkerinWstuff
    that's got to be extraordinarily frustrating.
    Be sure to let us know what you find out. Something must be going on that isn't letting the clutch disengage once the side cover is reinstalled. I've read posts where people have installed everything and had it bind where the starter motor wouldn't turn at all. I haven't heard of this happening (not that that would mean anything....)
  9. 80sNight
    80sNight New Member
    Taxachusetts
    You said it, Tink. If this bike has done anything for me, it's taught me unbelievable patience.
    Absolutely. I'm wondering if my torque wrench is messed up and is giving me wrong readings. Manual specs 90 (9, 65), which just seems so tight
  10. 80sNight
    80sNight New Member
    Taxachusetts
    My ever-wise and patient mechanic suggested checking that the relay isn't sticking... let's hope that I have just been really dumb about this
  11. tinkerinWstuff
    maybe you described the problem differently to him in person.
    A sticky solenoid on a motorcycle wouldn't allow the engine to overspin the starter.
    It could allow the starter motor to stay spinning and certainly burn it up. But I'm not aware of any way that would allow the motor to spin the starter.
    When I start my 3rd gen and it's warm, I have to apply 1/4 throttle. Once she fires, it rockets to 4k rpm right off the bat. The starter motor hasn't finished spinning but the engine isn't able to overspin the starter because of the starter clutch.
    So one of us isn't understanding the symptoms correctly.
    Bad solenoid could also "click" and not complete the circuit allowing the starter to spin. An analog volt meter on the heavy starter wire would show if voltage is being sent to the starter when the start button is pressed.
  12. tinkerinWstuff
    is it possible that the starter motor is turning like there's power still being applied
    but not being overspun like the engine is turning it?
    Your mechanic thinking that the solenoid is stuck and turning the motor? Seems coincidental that the only time it stuck was once the engine fired but not the numerous times you attempted to start prior to that. Anything's possible and worth investigating
  13. 80sNight
    80sNight New Member
    Taxachusetts
    Hm.
    1). Tink, thank you very much for helping me trouble shoot.
    2). I suspect my mechanic misunderstood me on the phone...
    3). I'm going to lay out the knowns and unknowns
    Known:
    The 2 fried starters are damaged inside: the first one I blew had a copper wire ripped from the cylinder around which it was wrapped. Black dust and small metal bits everywhere
    The starter clutch functions normally when removed from the crankcase.
    The starter clutch functions fine when returned to the crankcase, but is very sensitive to the tightness of the bolt.
    I am not a professional mechanic. At all.
    Once the starter dies, the relay clicks.
    The dead starters do not turn with voltage applied directly from the battery (see service manual for starting motor testing).
    The engine sounds encumbered when trying to start.
    Both starter motors worked at one point.
    Unknown:
    Why the starter motor is staying engaged.
    Why the starter motors are being destroyed within the housing.
    Why this sucks so hard
  14. VFR Man
    VFR Man New Member
    Scotland
    My first post but just read this thread, I recently bought a 2001 VFR800 and a couple of weeks ago after starting it I realised the starter button was sticking and had not been released after the engine was running. Stopped the engine which then refused to start as the starter solenoid was fried.
    Just wondering if your starter button is sticking also and needs cleaned and greased?
    Russ
  15. tinkerinWstuff
    I think this one belongs in the known catagory.
    The degree to which this sucks is very evident
  16. 80sNight
    80sNight New Member
    Taxachusetts
    1) Welcome, brother! Glad to have you on board.
    2) Not that, but I know exactly where you're coming from. It does stick, but my VF500 did the same, so I flick it open out of habit
  17. 80sNight
    80sNight New Member
    Taxachusetts
    Duly noted
  18. 80sNight
    80sNight New Member
    Taxachusetts
    Does anyone know if the parts from the starter for a VF500 would fit the VFR750 starter? I'm running out of money here, and there's a starter staring me in the face, sitting attached to my dead VF500
  19. WGREGT
    WGREGT New Member
    I had this same problem with my 94 VFR750. Replaced the starter clutch. Wouldn't fire. Turns out I had the reduction gear in backward. Not saying you did this, but it was easy to flip it around. Anyhow, check out this post @ #25 on page one. See if it does anything for you. As far as the 750/500 starter swap, check out Ronayers.com and see if the part numbers show up on both bikes.
    http://vfrworld.com/forums/mechanic...utch-repair-vfr750-pictures-2.html#post351211
  20. 80sNight
    80sNight New Member
    Taxachusetts
    Turns out I was missing a washer, and some other small and easily missed piece. WATCH YOUR PARTS, GENTLEMEN
