Starter Clutch T1, T2, T3, T4 marks on face of housing - pulse generator
Discussion in 'Introductions' started by christiano, May 16, 2011.
  1. christiano
    christiano New Member
    Hudson Valley, NY
    I have a '95 vfr750 with a cracked starter clutch housing.
    When replacing the starter clutch, do I need to mark the position of the starter clutch? It has hash marks on the starter clutch face as pictured in the post "replace starter clutch with pictures"? My question: is the clutch timed...by the Ignition Pulse Generator? These two pieces (pulse generator pick-up) are mounted right at the starter clutch wheel. And with the marks T1, T2, T3, T4 on the face ...I'm wondering if any misalignment when reassmbling will cause a problem. If you have any experience at this please advise. Couldn't find this thread in the forum.
    Chris
  2. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    I don't know, but I'm sure someone on here does.
    Consider your thread bumped.
  3. Davey
    Davey New Member
    I can tell you that I just completed the replacement of the starter clutch on my 95 vfr750 and I am having timing troubles... I am looking into it further myself, just bumping again... let me know if you have success with replacing yours.
  4. christiano
    Hudson Valley, NY
    I replaced the starter clutch, but when I removed it - I took the time to mark the placement of the T1 T2 T3 as if a clock. So when I put the new disk back on, I assume I did it correctly as the bike runs fine. I did not get feedback about the markings from anyone. My next choice would have been to simply ask the Honda dealer. Anyhow, that project is done.
  5. christiano
    Hudson Valley, NY
    One more thing. If I remember correctly, the splined shaft had a flat spot on it so the disk can only go on one way, thus - no jumping a space or so when remounting it on the spline. Brilliant. Nice engineering on this bike.
