Stalling issues
Discussion in '1st & 2nd Generation 1983-1989' started by merls86, Mar 13, 2009.
  1. merls86
    merls86 New Member
    new to VFR World I have a 1986 vfr 700, with 44,000 original miles.The bike is 99% stock with the exception of a K&N air filter.I'm having a problem of stalling.After 15 minutes or so of stop and go or even steady riding the bike bogs down and stalls.On occasion if I can catch it before it dies I put on the choke and it continues to run.Sometimes it stays running at others it stalls.Once on the side of the road :crazy:I would try and restart,with the choke on it would run for about 30 seconds then stall.Would have to let it sit for about 10 minutes restart then will run fine for the remainder of the ride.Have replaced fuel pump,carbs have been cleaned,resolved elect issue with start switch which ties into fuel relay.Have checked wiring to fuel pump and relay found no visible defects,have opened carbs and checked floats,jets and valves,nothing appeared bad....Any other suggestions,ideas that can help ? Thanks
