Squared off front tyre, Michelin PR3's
Discussion in '6th Generation 2002-2013' started by Gweglez, Jul 28, 2014.
  1. Gweglez
    Gweglez New Member
    Southampton, United Kingdom
    I'll get a pic up when I can but my PR3 front is squared/squaring off, it's noticeable when i run my finger over a solid bit of tread.
    Worth mentioning I've only covered 6k max on these tyres, had to replace the rear due to multiple punctures but from what others have said on here i should get at least 10/15k miles from the front. My riding is mostly straight line commuting but at relatively low speeds (30mph) and when i corner i try to lean as much as possible (it's good fun ;) )
    help?!?!?! cant really afford a new front, paying for a wedding here!
  2. Scubalong
    How is your air pressure? under/over inflate can ruin the tire quick.
  3. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    I ran two sets of PR2s on my bike - not exactly sure how much of a difference there should have been between the 2 and 3. But I only got about 6K miles out of mine.
    Is your air pressure OK?
    Maybe you can make switch to the PR2 in lieu of the PR3 - I think they are a bit cheaper (here in the US, at least). Use some of that wedding money!
  4. Gweglez
    Gweglez New Member
    Checked and corrected once a week with a digital inflator/pressure gauge, 36psi front/42 rear
    Are the pr2's still really good in the rain? that was the main thing that sold me on the 3's
  5. Pliskin
    Pliskin New Member
    I've heard the 3s were a little bit better in the rain. Never ran them myself, so I can't comment. Need to ask Randy from here - he's done lots of rain riding, and believe he's had both the 2s and the 3s.
    I never had issues with the 2s in the rain.
  6. Scubalong
    PR3 is supper in the rain I have tested myself several time. You might feel a bit of hydroplane in deep water spot but will get grip again if you
    pull the throttle :)
  7. roryforde
    roryforde New Member
    I have had the 2's and later the 3's - they have very different tread patterns; the 3's are superb in the wet without losing anything on dry roads. 6K miles doesn't seem right..should be getting 10K or so from the rear, and generally the front should last longer. I have not seen a front square off before - usually cupping is the normal wear from the front... are you sure it is not the dual compound margin that you are detecting?
  8. Robclo
    Robclo New Member
    ON
    I got less hen 6k miles on my PR3's and I'm a little anal about tire pressure.
  9. Badbilly
    The construction of the roadway ie the mix in the asphalt or concrete and the slope can affect tire wear.
  10. Gweglez
    Gweglez New Member
    Yeah I've got the 3's and i broke them in, in the rain. They were amazing, I'll take pics later for you guys to have a look.
