Sprocket changes -1 in front
Discussion in '8th Generation 2014-Present' started by brunetfVFR, Aug 17, 2015.
Tags:
  1. brunetfVFR
    brunetfVFR New Member
    Hello Viffers!
    I just bought my second VFR, but I cannot find any aftermarket front sprocket for my new 2014 VFR 800... any ideas? This is a must for me!
    Thank you guys!
  2. GigemVFR
    GigemVFR New Member
    TEXAS
    You try this? Many posters on here say this is their preferred place to get.
    www.jtsprockets.com
  3. SlideRule
    SlideRule New Member
    Temecula, CA
    When my chain wore out on my '14 I ended up getting a full chain combo for a 6th gen from sprocketcenter.com - stock chain size on the 2014 was 525 pitch, but I felt the 530 chain from the 6th gen would last a little longer. Everything bolted up without a problem (it is the same engine after all). Also, be careful changing your gear ratios, it will probably affect your ABS, speedometer & Traction Control if your bike came equipped.
  4. brunetfVFR
    Oh, forgot about the traction control... I will do some reading about that. FYI, I did change the sprocket on my previous VFR with ABS and I never experimented any differences.
    Thanks.
