Speedometer going crazy
Discussion in 'Mechanics Garage' started by Scubalong, Oct 12, 2011.
  1. Scubalong
    As I crusing on the hi way my gage showing 80 mph and suddenly it is showing I am doing 5 mph.........WTH, I pull into the parking lot and shut off the engine and restart take a spin and the gage still showing I am doing 0 mile per hour. I am thinking my speed sensor is out. What is your thought...?:crazy::crazy: Any input is greatly appreciated
  2. TOE CUTTER
    Check the coupler to the speed sensor, mine backed off once before and did the same thing.
  3. Scubalong
    Are you talking about the coupler by the grears box, can you send me a picture?
  4. TOE CUTTER
    Just remove the speed sensor and check the coupler and that it is mated to the ootput shaft bolt. Hooker. Picture shmicture.
  5. TOE CUTTER
    OK......I will take a picture.......................Hooker. Hold on.
  6. MrSleep
    MrSleep New Member
    Verdigris, Oklahoma
    The speed sensor is bolted directly over the front sprocket on the sprocket cover The coupler is a white plastic nut looking thing that actually sits on the bolt head of the bolt that bolts the front sprocket on. Mine got worn out and started setting FI light to come on. Yours may have broken completely. You can unbolt the sensor and, key on, spin the sensor end shaft by hand and it should show up on the speedometer. Other then the coupler it could be a bad sensor, bad wire -I think there are three from the sensor to the gauges, or a bad gauge (unlikely) Hope this helps!
  7. Scubalong
    Thanks Hooooookers and Mr sleep will take them off and do some inspection for damaged. Will report back soon :)
