Speedo problem after changing chain and sprockets!
Discussion in 'Mechanics Garage' started by Superceptor02, May 29, 2008.
  1. Superceptor02
    Superceptor02 New Member
    Tennessee
    Hey guys just wondering what you all thought. I changed my sprockets and chain today. When I went for the test ride I noticed that my speedo was bouncing all of the place and would not hold a consistent speed. So I went home and took out the speed sensor from the housing and then watched it go onto the bolt holding the inner sprocket on. It just barely makes contact. I also noticed that when I spin the rear wheel that the speed sensor seem to slip some of the time. Anyone had this problem? I am trying to decide if I need to take it all back apart and get a different front sprocket or just try to add a washer so that the speed sensor makes a better contact.
  2. VFR-Guy2000
    VFR-Guy2000 New Member
    Holladay, Utah
    When I did mine there was a spacer that had to go in with, if memory serves right, or the sprocket had to be facing a certain direction to work properly. You will also need a speedo healer if you don't have one already.
