Does anyone know where I can buy a set of speed bleeders for the clutch and brake lines on a GEN5 VFR? Also, if anyone has tried them, would you reccomend them? Thanks, Mel
Not sure on 5th gen, but on my 6th gen I purchased for the brake and clutch. They will not work for the clutch on the 6th gen. The threaded shaft on the speedbleeder is too long. I wish I had just taken everyone's advise and flushed the fluid using the stock bleeder. I made a mess trying to swap them and then again having to replace the stock bleeder. Cleaning that up took about 5X longer than just flushing/bleeding with the stock bleeder.
