Spark Plugs
Discussion in 'Mechanics Garage' started by duccmann, Nov 10, 2013.
  1. duccmann
    Ya ya I know..dont fix it if it aint broke. Was thinking last night (ouch) on the way home that I bought my bike 2 1/2 years ago with 1800 miles now has close to 17,000 and probably has the original plugs (2002) . Maybe I just dont know that it could run even better...runs great now. Any thoughts?
  2. Scubalong
    It is not hurt to put in the new plugs :rolleyes: they will burn better and cleaner. Don't you dare ask which type
    :chairshot:
  3. squirrelman
    Time for plug maintenance at least. Check that the center electrode is square and sharp without rounded edges and check/restore the proper .032" gap.
  4. tinkerinWstuff
    factory service manual for 5th gen specifies replacement every 8,000 miles.
    I'd guess the 6th gen isn't any different.
    8k seems a little excessive to me but they're cheap and not too difficult to replace.
  5. pacemaker
    pacemaker New Member
    Newcastle Australia
    I don't know about cheap. Here it's a $99 x 4 plugs & that's off ebay. That's a decent piss up & a bags of nuts. But I get your drift.
  6. duccmann
    Is there coil sticks also? At work or I would look it up in my manual. thanks guys
  7. OOTV
    OOTV Member
    When I changed mine, I just bought the iridium plugs that were listed in the manual (NGK), the "coil sticks" I left alone. In this case, I would say leave well enough alone and just replace the spark plugs.
  8. tinkerinWstuff
    I believe the coils are still mounted on the frame and uses a spark plug wire with a plug on the end that seals to the valve cover.
  9. tinkerinWstuff
    You can't be serious? That's nuts
  10. Scubalong
    :suspicious: :scared:
    Now I know where not to live...... :smile-new:
    Will mail you some from here if you need
  11. duccmann
    So riddle me this VFRdudes, other then oil changes and K&N filter swap--- So do I have to take the bike half apart to do the plug swaps ? Thanks
  12. VFR Love
    VFR Love New Member
    New York
    Nope, just some extensions for your spark plug socket (or regular deep socket with a lil tape wedged inside).
    I can't recall if I had to unbolt the tank at the hinge (rear). Something I did on the bike required it but I just left one rear bolt and swung it out of the way. (EDIT: I did- see my post below)
    In any event this is all to say it was a very easy job if you have a few simple tools and a 1/4 tank or less of gas.
  13. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    I changed the first set at 10k, she ran fine and they looked good. The next set was at 22k...running like on three cylinders, the plugs looked normal tho :confused:
    O'reilly's had the plugs for $5 each...the dealer was $10
  14. OOTV
    OOTV Member
    The 6 Gen uses "Direct Ignition Coils", which Duccmann is calling "coil sticks", which appear to be on all 6 Gens (2002+) according to the Honda FSM. I would have to assume that all 5 Gens have the traditional frame mounted coils, as that's how they are on my '01.
    The DI Coils are item 1 in this screen shot.
  15. fitzharris
    fitzharris New Member
    Eugene, OR
    VFR 2002 manual says "inspect spark plugs at 16,000 Miles replace at 32,000 miles ." The spark plugs are expensive and special handling instructions apply...it's all in the owners manual. Do not over tighten...very light torque if I remember correctly. I changed mine at 8,000 just because. You can find them http://www.partzilla.com/parts/detail/honda/HP-31922-MCW-004.html Yes! $27 a piece.
  16. OOTV
    OOTV Member
    Wow! I got mine from the local Honda dealer for $15.99 ea. (NGK IMR9B-9H)
  17. fitzharris
    Eugene, OR
    Yes, the NGKs a bit less, but still expensive. Can't remember why I went with the DENSO...musta been a good idea though. The DENSO's I pulled out at 8K looked pristine. However, they were 11 years old.
  18. duccmann
    Thanks fer the edumacation.....as my teen says
  19. ridervfr
    Belgium
    How can I beat that POM statement! Sweet...
    I went back to cheap oem style plugs I believe, I would not be my life on it as I have swapped lots of plugs in the life cycle of the bike...Cheers.
  20. VFR Love
    VFR Love New Member
    New York
    Bought mine on eBay for under 40 bucks (usd) shipped
    During install:
