Spark plugs issue
Discussion in '5th Generation 1998-2001' started by GWD88, Jun 20, 2013.
  1. GWD88
    GWD88 New Member
    Hi,
    I just bought new NGK spark plug for my 2001 VFR and when I look on ngk website and forum the correct spark plugs number is CR9EH-9 but my local Honda dealer sold me CR8EH-9 telling me the only difference is the heat they produce? Is he right? Is CR8EH-9 gonna be okay for the viffer?
    Thank!
  2. TOE CUTTER
    It is one heat range hotter, neither you or your bike will know the difference.
  3. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    The heat range has nothing to do with the "heat they produce".
    A "Hotter" plug will keep its tip at a higher temperature due to a longer insulator, a "Cooler" plug will keep its tip at a lower temperature due to a shorter insulator. That's it in a nutshell. It used to be very important when running two-stroke bikes since they would tend to foul colder range plugs. If you run a plug that is too high in the heat range it might get so hot that the overheated plug tip will pre-ignite the gas/air charge leading to detonation and possible premature demise of the engine.
  4. GWD88
    GWD88 New Member
    Allright Guys! Thank you very much for the helpfull replies!!
    I solved the problem by trading them for CR8EH-8, the dealer is at the corner so no big deal!
    thank again!
