so i got my new forks, brakes, carbs put on runnin damn good but the forks didnt not fix my steering problem so i got to lookin and messin around my triple and axle were bent so i found a few but heres my question does anyone know if the axle from a 91 and the upper and lower triple from a 97 will fit on a 93. also how hard or easy are the airtech fairings to install and anyone have experience/ step by step instructions or pictures or details or how they put theirs on?
The axle and upper triple are the same, the lower is a different number but would be suprised if it did not fit.I have installed Airtech in the past and they are race body work so you have to cut out the head and tail light openings, not that bad but does require a bit of time a patience.
yeah i got a set of forks from a 92 thinking that was my initial problem but then i pulled my triple and thats what it was. yeah i figured it was gonna take a lilttle time especially to make it back to stock with working lights i mean fabricating is no problem but its just gonna be tedious i just wonder about the lower triple if its the same length an what not cause that and mounting the fairings are my main concern that just seems really complicated but i mean im up to it more time consuming than id like
