Soft Saddlebags on 2002+ VFR??
Discussion in 'Gear & Accessories' started by tlc, Mar 25, 2007.
  1. tlc
    tlc New Member
    Calgary, AB
    Has anyone put soft saddlebags on their 02 or newer vfr? I'd like to use soft bags, but am concerned about the heat from the (factory) exhaust pipes being right there. Looking at using some GIVI brackets to help protect the bags and my stuff from the heat, but it'll be a pricey set up.
    Any insight would be greatly appreciated!
  2. tlc
    tlc New Member
    Calgary, AB
    Well - after doing a lot more research, I still hadn't come up with a solid conclusion about whether soft bags would be safe. While some posts (and other sources outside VFRWorld) indicated that factory exhaust wouldn't get hot enough to ruin the bags, there were a couple of stories I heard about needing to stop because the bags were "burning". Even a couple stories is too many for me.... So I ended up with the Givi hardbags. Pricey - but I suppose that's not too high for peace of mind that my equipment is going to hold together for the long ride we want to do in June.
    I've had them on for a few weeks now, about 1000 km - and so far so good.
    Cheers
  3. VIFFER RIDER
    VIFFER RIDER New Member
    Socal
    I want some hard bags too but they are expensive as hell. Even the used Honda offered ones ive found were like $500+
  4. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
