Smoking 6th Gen VTEC
Discussion in 'Mechanics Garage' started by NineFingerTommy, Feb 19, 2016.
  1. NineFingerTommy
    NineFingerTommy New Member
    Indianapolis, IN USA
    My bike has a smoking problem and needs help kicking the habit.
    At low revs there is no issue. But after a hard ride when I come to a stop I get quite a bit smoke coming from the front of the bike somewhere. The engine is running fine and is not making any noises. Nothing abnormal from the exhaust. Smoke comes out of the front end and sometimes up through the bars. It smells like oil smoke. No oil drips under the bike. I think it might be a seal or gasket in the VTEC system but I am not sure.
    Any ideas or suggestions would be greatly appreciated.
  2. Aimbot9000
    Aimbot9000 New Member
    Mount Holly,nc
    Only thing I can think to do would be taking some bodywork off wash the engine with a good degreaser then take her for a ride to try to catch her in the act and proceed from there. While your looking for oil lift the tank and check the crankcase vent hose isn't bad because it can drip oil onto the block.
  3. Underoath87
    Underoath87 New Member
    Orlando, FL
    Are you using one of those shitty K&N filters? Many of us have encountered a leaky one.
  4. NineFingerTommy
    I am using K&N. I wasn't aware of a leak issue with them. I will give that a look.
  5. Underoath87
    Orlando, FL
    I had one that started leaking at the end nut during a 400 mile ride that left me stranded on the side of the highway at night and almost destroyed my engine.
    Most others have seen leaks develop at the seal.
  6. sunofwolf
    sunofwolf New Member
    Header leak:drum:
  7. Lint
    Lint Member
    Simi Valley, Ca.
    Does the smoke smell sweet? Check your coolant level. Smell goes a long way in diagnosis.
  8. NineFingerTommy
    It is def oil smoke.
  9. NineFingerTommy
    I think it might be the filter. Upon further inspection it seems to be where the issue is coming from. Oil change is happening this week. We will see if a fresh filter fixes the issue!
  10. Lint
    Lint Member
    Simi Valley, Ca.
    :clap2::clap2::clap2::clap2:
  11. mello dude
    Shit can it!
  12. sunofwolf
    stock filters or emigo cheapest best
  13. Aimbot9000
    Mount Holly,nc
    Nice catch Underoath87
    As for future filter choices
    http://www.calsci.com/motorcycleinfo/FilterXRef.html
    Recommended filters.
    All have superior filtering.
    About 2.5 inches long.
    Purolator Pure One PL14612, about $6.
    Mobil M1-108, about $12.
    Made by Champion.
    Bosch 3300, about $6.
    Made by Champion.
    Wal-Mart SuperTech ST6607
    Made by Champion.
    About 3.25 inches long.
    Purolator Pure One PL14610, about $6.
    Mobil 1 M1-110, about $10.
    Made by Champion.
    Bosch 3323, about $6.
    Made By Champion.
    WalMart SuperTech ST7317,
    about $2. Made by Champion.
    Prices are wrong
