anyone done this mod yet?? Ebay has a TPO smog block off kit for sale...I cant get the link to work... TPO Honda VFR800 Interceptor Emissions Removal:eBay Motors (item 250428734292 end time May-27-09 17:59:22 PDT) just curious to see if its is worth it?? thanks
Kit? All you do is to remove the parts, block the vacuum ports, the airbox ports, and make your own AL plates patterned after the tubing gaskets going into the heads. Reuse the old bolts and some high temp gasket cement. Hardest part, getting the old tubing off. I ended up cutting mine the pieces, throwing it away anyway. Larry VFRrider
