Side stand switch replacement?
Discussion in '5th Generation 1998-2001' started by bladrnr, Dec 6, 2011.
  1. bladrnr
    bladrnr New Member
    Santa Rosa,CA
    How hard is to replace the side stand sensor switch? Is it something a mid level amatuer mechnic can do?
  2. DaHose
    DaHose New Member
    Napa, CA.
    Should be very easy. The sensor bolts "on top" of the sidestand bolt. Look at the pivot and you will see a small bolt head (probably a 10mm) holding on a plastic piece. That is the sensor. Unbolt and it pops off. Disconnect from wiring and replace.
    Jose
