Should my bike heat up at full throttle?
Discussion in 'Mechanics Garage' started by ndulucky13, Oct 4, 2010.
  1. ndulucky13
    ndulucky13 New Member
    ok so i have a 1984 vf500 and when i give it full throttle it heats up maybe 1/16" to 1/8" then cools back down. any ideas?
  2. mrvfr
    mrvfr Banned
    just a shot in the dark here, your temp sensor could be goin out.
  3. donald branscom
    donald branscom New Member
    Guerneville CA
    Of course it gets hot at full throttle!!! Cheeeesssshhhh!!!!
    Don't you have some cleaning t do?
  4. mrvfr
    mrvfr Banned
    how quickly is the needle responding?
  5. ndulucky13
    ok so did some more riding and now when it heats up an 1/8" it stays there and gets hotter when just idleing with the fan on. I would say right after i hit redline in the gear then let it back down to like 4k it starts to move and moves 1/8" in like 10 or 15 secs
  6. tinkerinWstuff
    that 500 won't be lasting long if you keep red lining it. The top end of the VF isn't robust enough to handle it - especially 30 years later.
  7. ndulucky13
    anyone know where to get a temp switch?
  8. donald branscom
    Guerneville CA
    Temp switch????
    Do you mean sending unit?
    temp guage?
    radiator fan switch sensor ?
    Which one??????
  9. ndulucky13
    the one that controls what my gauge says? and could i maybe upgrade to one that reads actual numbers instead of a scale
  10. donald branscom
    Guerneville CA
    Yes that is possible.I did it on my bike.
    The temp sensor is mounted on the thermostat housing.
    The temp sending unit is dedicated to the guage. They are a set.
    Photo of digital guage.
    When first turned on it reads LO then after a couple minutes it reads temp numbers.
  11. ndulucky13
    where did you find this at and how did you install it?
  12. ferrarone
    ferrarone New Member
    Manchester, NH
    You put stress on the engine and it heats up a little, cools down when you relieve the stress. Heats up at idle, cools down on the move. I don't see a problem. This is exactly how this bike is supposed to function. However, your 500 will be blowing it's brains out soon if you redline it. I love the 500, but it's got a pretty fragile engine in it.
