Should I grease it??
Discussion in 'Mechanics Garage' started by Kerby, Jun 13, 2013.
  1. Kerby
    Kerby New Member
    CT
    I just removed the front wheel on my 6th Gen becuase tomorrow I'm putting on a new tire.
    I'm not a seasoned rider as some on here on the board so my question is should I grease the spacers and the axle bolt when putting the wheel back on? If I do, what grease should I use?
    Thanks.
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    The wheel bearings are shielded so you really can't get any grease into the balls very easily. You can pry off the shield and try to get it back on after you tried to put some grease in, but personally I'd check them and if they were smooth I wouldn't mess with then. A little anti-seize on the axle and call it good.
  3. squirrelman
    Yes, the axle should have wheel bearing grease applied, but not on the bolt/nut. Should use a torque wrench when tightening unless you're very familiar with the hand/arm/body forces needed for proper installation. Pump up the front brake after wheel is mounted.
  4. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I just thought about it, but on the 5th gen you need to check the clearance of the disk/rotor because they tend to be pretty close. I assume the 6th is the same?
  5. ridervfr
    Belgium
    Always grease your axle Kerbster, its just politically correct in this day and age. Don't go crazy with the grease, and don't get Midieval on those pinch bolts either...Cheers
  6. duccmann
    What size hammer you useing for torqueing the bolt ? ;)
  7. bitterpil
    bitterpil New Member
    Northern Virginia
    I always clean and grease the axle and spacers. I also put a thn layer over the bearng shield mostly as a water repellant since here is a shield there aleady.
    I have my wheels off several times a year for tire changes and such.
  8. bitterpil
    Northern Virginia
    I use a 10oz finish hammer to torque the small pinch bolts then a 20oz framing hammer for the larger axle nut.
  9. Durk
    Durk New Member
    Pittsburgh, PA
    I have a big tub of red colored GM suspension grease that I put a thin coat on the axle with.
    It's always more work getting a rod in a hole without some lube.
  10. bitterpil
    Northern Virginia
    You can aslo use a lil sweet talkin' and ply with a lil alcohol. If you do this early enough in the process you may need a little less lube to get to get the rod in the hole.
  11. duccmann
    Hey hey hey...thought we were talkin about his axle......ooooooh I get it......:hump:
