shifter mod
Discussion in 'Mechanics Garage' started by esacfrank, Jul 5, 2006.
  1. esacfrank
    esacfrank New Member
    Newington, CT
    list wisdom please:
    the bike is a 1998 and i find my boot is too big to easily get under the shifter to up shift. if i reposition the lever up to make it easier to get my boot toe under the lever then i have to remove my foot from the peg to down shift. are there any shirter arm mods folks are aware of or even some how moving the foot pegs rearward?
    tia
    frank
    newington, ct
  2. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    rearsets, as I have read in descriptions, would mover the footbeg up and back about 1 inch. I have the opposite problem you do, as my feet are a little short and I am using the end of my boot to shift unless I rest my heel on the peg. Most fo the time I get a good firm shift, but sometimes I dont. I was gonna buy an extra shifter and modify it to make it longer, but I havent done that yet.
  3. RVFR
    LOL get smaller feet, or seriously try different boots/shoes.. you no those groves in the out shaft can be tricky to get it right so might want to try again as I've seen it were you actully move it to far and there's another postion between. Vamn get bigger feet better yet swap feet with escafrank LOL
  4. WhiteKnight
    London, Ky
    LOL Got em on order. Won't be her for another 50 years or so. lol
  5. RVFR
    Well hell man get some different boots. you know do as the the girls do, need more than one pair ya know. if it's good for them, I say it works for us too.
  6. WhiteKnight
    London, Ky
    Looking at some Set Up (i think thats the name, its a low priced boot by Sidi) boots.
  7. RVFR
    there ya go....
  8. esacfrank
    Newington, CT
    pegs
    hi everyone and thanks for the replies/suggestions. i have an appointment with the surgeon for toe removal and will get smaller boots :smile:
    actually i am going to remove the shifter arm and head on down to my friendly honda dealer to see if a shorter shifter is available. i think the perfect fix would be a lowering block which would move the peg down and rearward.
    anyway thanks again for the replies.
    frank walsh
    stoc#205
    '98st1100a
    newington, ct
  9. tooslow
    tooslow New Member
    Take the footpeg off-buy a hardened bolt in lieu of the stock pin--place peg on lower half of mounting bracket--secure with bolt and lock nut--you will gain 1/2"
    by lowering the peg creating clearence for your boot.
  10. esacfrank
    Newington, CT
    tooslow:
    thanks for the tip i will try it this weekend.
    frank
