Sheared Rubber Housing on Throttle Cable - Any Adverse Impact?
Discussion in '6th Generation 2002-2013' started by Civicblade, Jan 24, 2011.
  1. Civicblade
    Civicblade New Member
    Just noticed that one of the throttle cable (comes in a pair) had the rubber housing sheared, exposing the metallic lining within the outer rubber shell.
    This must have been caused by the constant abrasion of the throttle cables again the fairing/headlight stay.
    Is there any adverse impact of keeping the throttle cable as it is, with the metallic sleeve exposed?
    Are throttle cable replacement a lot of work? Does the fairing and tank needs to go off first?
  2. TOE CUTTER
    What gen are we talking aboot?
  3. Scubalong
    A tape my and zip tight them where the cable make contact.........Problem solved.
  4. Civicblade
    Mine's a gen6. The throttle cable at the end nearer to the throttle grips are zip tied to the fork tubes.
