Searching Wirering Plan for Marker Lights
Discussion in '6th Generation 2002-2013' started by bruzito, Aug 9, 2010.
  1. bruzito
    bruzito New Member
    Hello all,
    i have a 6th Gen VFR (European Modell). And i would like to bring the marker lights in the turning signal to work.
    I found on the internet only a lot of wirering plans for VFR's with no marker light connection. Like it is outside the US.
    Does anyone has a wirering plan with the US wirering...
    I don't know where to connect the marker light wire... so that when the turning light is blinking, the marker lights switches off... like it is in the US...
    Can somebody help me out...
    Thanks and greatings.
    Roger from Switzerland
  2. vfr2k2
    vfr2k2 New Member
    Ontario, Canada
  3. cecilio64
    cecilio64 New Member
    Valdemorillo, Spain
    I just did this on my VFR but backwards. I found EU wiring diagram and US diagrams, which I've attached. The difference between the two is the front wiring harness, LH switch and some relays are different. The US one has a relay/flasher for the position and turn signal lights. This is what sends a lower wattage through the same wires that send the higher wattage "turn" signal. Looking at the EU wiring, I suppose you could add a socket that accepts a dual filament bulb in place of the current turn signal one and then reroute the feed from the position light in the headlight to the new dual bulb.
    sorry, but I can't seem to upload the files. I can PM them to you if you want, let me know.
