rust solution on exhaust pipes??
Discussion in 'Mechanics Garage' started by VFRidder, Sep 9, 2009.
  1. VFRidder
    VFRidder New Member
    hey all....my 98 looks great but the exhaust pipes have some rust or discoloration......is there any solution for this..??
    i just dont think high heat paint will hack it.:confused:
  2. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    Are you talking about the headers/collector pipes or the muffler itself? If you are talking about the headers/collector pipes... some steel wool will clean them up and then your can high temp paint them or ceramic coat them.
    If you are talking about the muffler, and it is bare metal, some very fine steel wool followed by some polish should clean things up quite well.
  3. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    I also forgot to add that if it is just the header/collector pipes that have discoloration and not rust, there are a few options that you can do. I've had luck with products like Tarn-X. I have also had several friends that have used the gel Lime Away and smeared it all over the pipes and let it sit for a few hours. A little rubbing later a majority of the discoloration is gone.
  4. mofoco
    mofoco New Member
    Vancouver Island, B.C. Canada
    on my 97vfr i used steel wool and high temp silicone paint from DEI an exhaust wrap company, turned out pretty good.
  5. VFRidder
    VFRidder New Member
    yep its the collector pipes that I Mean.
    so steel wool the rust off and high temp paint it?
    its just hard to believe any paint can withstand the temps the collectors reach.
  6. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    There are two types of high temp paint (more actually but not all are easily available) that you need to watch out for. There is high temp engine paint and then they also have high temp header paint. You want to make sure you get the high temp header paint such as the stuff Mofoco mentioned.
  7. VFRidder
    VFRidder New Member
    ahhh okey....il take a look for taht...thanks again guys
