Ruff Running
Discussion in 'General VFR Discussions' started by katat58, Sep 2, 2009.
  1. katat58
    katat58 New Member
    Hazen, AR
    Hey all, I just pulled in from work and with the bike still idling I gradually started on the throttle and between 2000 and 3500 rpms the bike really runs ruff, it's not a smooth transition from say 1800 rpms to 3500 rpms or so. You can't hold it at one rpm range without the engine running up or down and when you throttle it's just a tad ruff, acting as though it not getting fuel or has a miss. Once you throttle up into the higher rpms at idle say around 4 to 5000 it smooths out but still has a slight miss, that's the best description I've got. It's an 06 with almost 11,000 miles on it. It starts great idles good and out on the road runs like a scalded dog. The only mod is I've bypassed the O2 sensors with the resistors. Everything else is stock and original. Any suggestions?
  2. Ghost_Rider
    Ghost_Rider Active Member
    LA & Utah
    Sorry, don't know what "ruff" means....is that scooby-doo talk?
  3. Rubo
    Rubo New Member
    I suggest you go back totally stock with O2 sensors and see how it runs.
    If still the same then check the fuel lines,Is the tank breather hose open? It is possible to get contaminates from bad gas which could clog up the fuel filter.
    I am not a mechanic but just making logical guesses. Go ahead to original stock condition and see if that works.
  4. katat58
    katat58 New Member
    Hazen, AR
    We can't use a little humor here? Rough, as in, not smooth. How's that?
  5. katat58
    katat58 New Member
    Hazen, AR
    I've done as you suggested before and it runs the same. I'll check the fuel lines and filter this weekend and thanks for your inputs.
