Roadstercycle R/R cable lenghts? SH847 pictures on a 5th Gen VFR
Discussion in '5th Generation 1998-2001' started by JACBR1KRR, Dec 27, 2021.
  1. JACBR1KRR
    JACBR1KRR New Member
    Please post your pictures of an SH847 on your 5th Gen VFR. What cable lengths did you order for you specific mounting location.
    I purchased my 98 VFR800 with 13.5k miles in July/2019. I added a VFRness, digital Volt meter and a Sparkbright Eclipse LED volt meter. My VFR already went thru 1 R/R with the previous owner. I believe the one on the bike right now might be a Rick R/R. ( no way to find out, previous owner passed away, his family had to sell his bike and gave me the old stock R/R). My VFR currently has 23.5k miles.
    I got some weird readings about 2 month ago while stuck in traffic for a long time. and my eclipse LED was blinking RED. Bike started to idle really low. Kinda wanting to die. Now I don't trust that R/R and the VFRness to be enough.
    I want to upgrade to the Roadster Cycle R/R SH847 to be specific. I understand is very large and probably not necessary over the FH020AA. I've been stranded many times on other R/R prone bikes. Not fun!
    IF there are not many options, I will go with the FH020AA. Which cable length did you get?
    Can you post your mounting location pictures on your 5th GEN for both Roadstercycle R/R, preferably the SH847 . What cable lengths did you get? mounting bracket?
    Bike will be my daily commute bike with 2-3 trackdays a year.
  2. ridervfr
    Belgium
    hope this helps
      File size:
      199.1 KB
      45
  3. raYzerman
    raYzerman Member
    Millgrove, ON
    Talk to Jack.... I think the FH020AA is OK, but for a series regulator, why not go with the SH775? I got the longer harness, but I don't believe it was necessary.
  4. mello dude
    Running the FH020AA and it's fine....I also had my stator rewound with long leads to go to the R/R and now have the R/R connector direct. -- There's no intermediate connector or solder going on......
    So, the question is, how are you planning to wire it up? Are you using the OEM stator?
    Suggest step back , search for for "the drill" charging system test.....
  5. tirso
    tirso New Member
    mello dude likes this.
  6. mello dude
    I like SF's mount method, a bolt up on the top side and then building kind of a clamp style below the lower subframe. Not bad....didn't realize there is room there. Not really a fan of drilling into the subframe directly, It's adding a stress riser at the loaded area.
    I have a 847 mount design for 5th gens, simular to the 6th gen mount plates, but in general the mounts haven't been selling enough to break even on this stuff.....
    I am blown away on all this charging system failure stuff is still going on for all these years!
    As a btw..... if any of the Roadstercycle R/Rs are wired correctly, the VFRness is a waste of good beer money....
    tirso likes this.
  7. Spensersdad
    Spensersdad New Member
    Northern California... way northern
    I mounted my new FH020AA reg/rec to the stock mounting plate for the original reg/rec. No adapter plate or clamp required. I drilled the top hole beneath the top subframe tube, and the bottom hole above the bottom subframe tube. The only modification I had to make was to delete the acorn nut from the top mount and replace it with a regular M6 x 2.00 nut. There wasn't room for the flared bottom part of the nut so close to the top tube.
  8. NorcalBoy
    Rivnuts work great in that application. Still a nice install.
