Reviving a 1991... and center stand question
Discussion in '3rd & 4th Generation 1990-1997' started by Crenninger, Apr 22, 2017.
  1. Crenninger
    Crenninger New Member
    Hi everyone,
    I will likely pickup a 1991 from a friend estate next month.
    I've had a 87 and 93 in the past so I kind of know the bike well. This was well before forum times ;-)...
    The 1991 will need full tlc has it has been sitting for a while.
    One question, the bike has a full setup twin brother exhaust with left side (chain side) exit.
    Is it possible to install a center stand on the bike?
    Thank you
  2. Hingley
    Hingley New Member
    I think it will depend on the exhaust system itself and how it is designed
    I have a 1990 with a full Yoshimura system and after I found a centre stand for it I found out the OEM centre stand will not bolt up to the factory mounting points, the stand will hit the exhaust pipes
    I think you maybe able to cut and weld short extensions to the stand for it to fit but it would be a lot of work
    So can you post a picture or two of your new 91, would be cool to see the exhaust system on the left, how many miles?
  3. ridervfr
    Belgium
  4. Crenninger
    Thank you
    I don't have the bike yet, late may likely. I added one pic in the first post, that's all I have.
    It's got 24k miles on it.
  5. ridervfr
    Belgium
    Nice! My black one has 80,000 almost a one owner bike, my white one had 15,000 when I got it, now it has 25,000. white.jpg
  6. Hingley
    Hingley New Member
    Nice pair, the white with blue seat is different, am I right to think you added a rear fender flasher light at the bottom for safety?
    Is that a slip on Yoshimura that bolts onto the original collector? Hard to tell in the pic
  7. duccmann
    Crenninger sweet ride--- welcome and let us know how it go's once you bring her home.
  8. Crenninger
    thanks, will do.
    I am preparing a list of TLC before getting it back on the road...
  9. ridervfr
    Belgium
    Bought an un-cut rear fender to replace cut one, slip on Yoshimura can, no strobe. I had a strobe built into my black one when I bought it, had a mercury switch hooked up so that it only flashed when I slowed down. It burned out and I got a replacement centre cowl in granite blue. bikelift.jpg
    Keep us posted on your progress
