Retuning to stock exhaust can
Discussion in 'Mechanics Garage' started by DVMSVFR, Apr 14, 2008.
  1. DVMSVFR
    DVMSVFR New Member
    western NC
    I have a 99' VFR800 which has a Yoshimura slip on I want to replace it with the stock exhaust. Is it literally unbolt, replace, and bolt on? OR do I need to automatically replace something like the gasket/gasket ring etc.
    Thanks.
  2. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    Yes, it's that easy!
  3. flameface
    flameface New Member
    New England
    exhaust slip on
    The stock can uses a "packing" gasket of sorts that fits around the header pipe to make a seal when you tighten the slip-on clamp. Some aftermarket pipes (Staintune for sure) require that this packing be removed. I don't know about Yosh pipes but it might be a good idea to order a new header gasket before you swap out back to stock.
    Why go back to stock? Too loud?
