Replacing Fuel Pressure Regulator on VFR800
Discussion in 'Mechanics Garage' started by signal, Sep 19, 2013.
  1. signal
    If I replace my FPR on my VFR800 (2003) do I have to replace any gaskets? Or should I be ok?
    If I do need the gasket, is it just something i can match at a parts store, or should i order the gasket set (which looks like it includes ALL the fuel rail gaskets).
  2. TOE CUTTER
    For the $13 buck Bike Bandit is asking for the set I would just purchase the gaskets and replace it. Possibly the best money you could spend if you factor in gas, time, and anger spent trying to hunt down some obscure seal from a parts guy that does not want to help you. Just say'n.
