Removing of gauges on 6 gen
Discussion in 'General VFR Discussions' started by duccmann, Feb 3, 2014.
  1. duccmann
    Wanting to know how difficult it is to remove the cluster. Can I just remove the screen and get it that way or to I need to remove the whole front fairing?. Also is it just one big plug or are there several to get to ?. Thanks in advance mang
  2. TOE CUTTER
    Your gonna pull the upper off, and then you can get at the cluster with ease.Don't really remember the wiring so it must be unremarkable. If you put your mind to it it is only aboot a two beer job.
  3. duccmann
    Very cool...thinkin of blue gauges doin there thang to it....thank
  4. Scubalong
    It will not be easy to swap to Blue gauge but my hat out to you Sir :)
    When you done mine is at home waiting for you to work on :pound:
  5. duccmann
    Ya there web site says pull it, ship it and its plug and play when they return it 24---48 hours after they receive it. $60. .
  6. TOE CUTTER
    Got a link? :typing:
  7. stoshmonster
    stoshmonster New Member
  8. Allyance
    Allyance Member
    Germany
    East Bay, California
    Out working on my 6th gen, replacing bad LED H4 lamp, you do not have to take off nose fairing, just the windshield, instrument cover, including left and right small fairing pieces. You can probably just loosen up side fairings, but almost as easy to take them off too. Two Phillips screws on back of cluster holds in on frame. Multipin connector and two wires under two smaller Phillips, that's it.
  9. duccmann
    Thanks man, you guys are the best.
  10. Allyance
    Allyance Member
    Germany
    If you do decide to take off nose fairing, put a towel or cardboard on top of fender to protect it. Fairing can easily scratch fender. Another tip, if you plan to take on and off once in a while, extend temperature sensing wires, a real pain to hold fairing and try to undo connector.
  11. Scubalong
    What you send it out to Blue guage......Puss.......:pound:
  12. duccmann
    Not yet...meow...ruff
    Sent from my SGH-T679 using Tapatalk 2
  13. Allyance
    Allyance Member
    Germany
    I looked at their pictures, and they look cool, I think I would go with blue on left & right and leave tach white.
  14. onelastwarrior
    onelastwarrior New Member
    Alabama
    Let me know how long it takes. I was going to do it and use $25 overnight
    Sent from my Nexus 5 using Tapatalk
  15. jev.
    jev. over there
    I had them do mine up in red several years ago. They did an excellent job.
  16. duccmann
    Jev...I love that avatar...do you know the twins?
  17. jev.
    jev. over there
    Most certainly
