Removing Cyl Heads in a GEN 1. IM STUCK
Discussion in 'Mechanics Garage' started by anarchy13, May 11, 2012.
  1. anarchy13
    anarchy13 New Member
    Germany
    so cams r out now 2 problems.
    not exactly sure of the names but i think its called the chain slack aduster and it wont come out cause its connected to the chain slider (some rubber peice that keeps it aligned and from rubbing on the inside of the engine) and thats bolted to the inside of the engine down DEEP!!!!! the other thing is i cant pry the heads off. i tried on both sides at the the same time that sucker is stuck!!!!!
