Hey Guys. Need some help on removing the plastic center Meter Panel on a 6th Gen VFR. I've done everything the service manual said to do, but I'm afraid to pull any harder in fear of breaking something. What I've done so far: 1. Removed Windscreen 2. Removed the two plastic tabs (push type to release) on bottom of meter panel. 3. This is where I need some help. Service manual states to pull off. Well, it appears there are some tabs to the right and left that fit underneath the tab. Again, any suggestions?:yield:
Sorry dude, thats one of the few pieces i haven't taken off the bike. See if you can see anything in this picture that would help. I can e-mail you a higher res copy if you want. Action
Thanks Action. That's Funny......you've got every piece around it off but the panel cover. Upon futher inspection there are two plastic tabs running through a rubber gromet on both sides. I have tried pulling it "gently" but I swear if I were to use all my strength, the tabs would break.
