regulator/rectifier scenario!
Discussion in 'Mechanics Garage' started by fulcrum51, Oct 3, 2006.
  1. fulcrum51
    fulcrum51 New Member
    From what I've read here, it seems like once you have the regulator/rectifier frying problem, you have to replace the regulator/rectifier, stator, wiring, and maybe the battery to start fresh, and then you'll want a custom fan for the new r/r too. Even then it doesn't sound like the problem is always solved. What a pain!
    I'm thinking of getting either a 2000 (because of the gear driven cam engine)or a 2006 VFR, but I sure don't want to inherit that kind of a problem!
    Does anyone know what years does the r/r & stator & wiring problems affect?
  2. Nailer45
    Nailer45 New Member
    Herrin,,ILLINOIS
    Honda has updated the stator and regulator for the VFR so they dont fry ..The wiring problems still plague the 6th gen as there is even a long thread about it at www.VFRdiscussion.com . Ground wires melting / connectors melting ..Honda neeeds a new electrical wiring tech.
  3. ZonaMan
    ZonaMan New Member
    Tucson
    I bought a 98 not knowing about the charging probs. I have replaced the RR once and am still having probs. I have used Electrosport's flowchart and everything and still can't pinpoint the problem. I have finally given up and am taking it to a Honda tech. $65 for a diagnostic to figure out what is wrong. This better f'ing work!!
  4. Rev
    Rev New Member
    Olympia,WA
    Well, the r/r's DO go out in them but I don't think I've ever heard of a bad stator. I just replaced the r/r and battery on my '94; the stator tested fine. You can test most of the charging system yourself with a multimeter: the r/r is the only part you should have tested by the dealer as they use two specific ohmmeters to do so.
    I didn't feel like paying the dealer $230 for a new r/r so I got mine from GDL Cycles in Florida for $120. Also I bought my battery at Sears; the replacement was the exact same one I'd buy from the dealer. Made by Yuasa, fitted with a DieHard sticker and $20 less.
