Rear Swingarm Stuck '85 VF700F
Discussion in '1st & 2nd Generation 1983-1989' started by Shawn Duffee, Jul 4, 2023.
  1. Shawn Duffee
    Shawn Duffee New Member
    Hi guys and Happy 4th of July!
    I am waiting for a new rear shock. I had the bike up on the rear stand with the shock off. I bumped into it moving something around and it fell back and down all the way to the wheel. After getting it back on the center stand, the swingarm will not go down. It is stuck almost all the way up. I can put a jack under the tire and raise it an inch or so freely, and back down the same, but it is catching somewhere. It doesn't make sense...it should just fall back down...I guess the mufflers anc wheel are coming off, then the linkage. So much for an easy and quick swap....
    time for a BFH ?
  3. Shawn Duffee
    Break For an Hour?
    Tried a Big F'n Hammer....
    Sent from my moto g stylus (2021) using Tapatalk
  4. squirrelman
    if the hammer didnt work maybe the linkage is stuck, not a common problem. small chance that shock is stuck.
  5. Shawn Duffee
    Yeah, first I'll get the wheel off and be able to get to the linkage easily. Sigh
