Rear Shock swap
Discussion in '6th Generation 2002-2013' started by Pacificman, Dec 17, 2009.
Tags:
  1. Pacificman
    Pacificman New Member
    Southern California, Ventura County
    Hello All,
    I have located an Ohlins 46PRXLS (model HO-9410) shock set up for a 929. From what I gather here this may be a good candidate for a swap on my 2002 VFR. Please advise. I weigh 220, so I presume a spring change will be needed. 2nd option is my friend's 954 take off and a "heavier" spring from an Ohlins that he put on his bike. He weighs less than I do. He has the spring and take off sitting around. 3rd option a stock f4i shock, I presume this will need more mods, but it is less costly than the Ohlins. What are the pros and cons of these 3 options? Thanks
