Rear shock question
Discussion in 'Mechanics Garage' started by Rev, Oct 25, 2006.
  1. Rev
    Rev New Member
    Olympia,WA
    I have seen several posts about adjusting rear shock settings but what I haven't seen (or found, anyway) is where on the shock I would find the adjuster points. In other words, where on the shock is the Preload adjuster, the Compression adjuster, and the Rebound adjuster located?
  2. Rogue
    Rogue New Member
    I presume you don't have an owner's manual then ?
    assuming it's an original equipment shock then the adjusters are as follows :
    1) Preload: there is a round hole in the frame on the left side through which you place the extended (8mm I think) socket wrench found in your toolkit. You turn this clockwise to increase preload.
    2)Damping adjuster : there is no seperate adjuster for compression/rebound only one for both. This is located on the bottom shock mount and is adjusted by screwdriver.
    http://www.ronayers.com/fiche/200_0295/rear_shock_absorber_94-97/rear_shock_absorber_94-97.cfm?man=ho&groupid=11570&parent=11550
    Easy to see here..
    Hope this helps.
    Rod
  3. Rev
    Rev New Member
    Olympia,WA
    That's what I was looking for. Thanks!
