Rear Sets
Discussion in 'Mechanics Garage' started by gira, May 17, 2006.
  1. gira
    gira New Member
    Any suggestions on rear set modifications. Peg is still grinding on tight corners on track days.:confused:
  2. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    I have not seen rearsets for the VFR. I also have the same issue and I usually run with the back end as high as I can get it (which usually screws up the sag) but gains clearance. I also hang waaayyyy off the bike so I can stand the bike up as much as possible. It still touches the pegs a bit.
    The only real answer is a track bike built for the purpose.
  3. gira
    gira New Member
    I am beginnng to realize that. Thanks
  4. Legs
    Legs New Member
    Birmingham, AL
    Stop doing that
    :tongue: To paraphrase Kel Carruthers to King Kenny when he was blistering his knees and grinding pegs on his TZ 700.
    "Stop doing that"!:drum:
    Best answer I can come up with other than build a trackbike.(Like Jethro):tongue:
  5. Joe Foe from Buffalo
    Joe Foe from Buffalo New Member
    I have a set on my 97 form Germany from this VFR website that had a group buy going on years ago but may be off line now.
    http://vfron-forum.vfr750.com/
    I honestly never liked them thinking what just happend would have happend long ago. Some one backed in to my steed and knocked it over and the pegs don't fold up and the wieght of the bike broke my frame at the rear set mount. Check this page for details
    http://www.bikepics.com/members/joefoefrombuffalo/
    I may/should sell them along with 900rr rear sets if anyone still looking....let the bids begin. Details on useing 900's
    http://www.hawkgt.com/kb/article.aspx?id=10105
    I'm going back to stockers.
  6. jethro911
    jethro911 Member
    Any chance they will fit a 98?:confused:
    I'm just dreaming.
    As I cannot afford a track bike the VFR will no doubt be pressed into track service yet again and the pegs will get a weight reduction via asphalt abrasion technique. Noisy, but effective!
    :first:
    Once again, in my dreams.
  7. Joe Foe from Buffalo
    I would also like to know if they will fit on 98+ VFR's. Check this info out and let us know. Are the mounting holes for the rearsets exactly 78mm apart? If so they will fit each other.
