Didn’t see this post anywhere prior and think I know the answer but need reassured ...... When stated either in the user manual or recommended suspension settings "Clicks form minimum setting" Would this be from the "last" click ? OR "The last click with any detectable tension" against the adjuster ? I can probably go another 8 or more "Clicks" past the point where there's any noticeable tension left against the adjuster Can someone clarify this for me , I've never had experience with an adjuster that went so far past any detectable tension on the adjuster Thanks in advance !! Ken
From experience - mine doesn't even move - you turn the adjuster counterclockwise until it goes no further. The first click you feel/hear when turning clockwise is the minimum setting. You can see the top hydraulic ring push on the spring as you turn the knob clockwise. I'd be glad it still works although come to think of it, it doesn't sound like it does.
