rear fender removal
Discussion in 'Mechanics Garage' started by jrj, Oct 10, 2006.
  1. jrj
    jrj New Member
    Calgary, Alberta
    I need some advise on this one. I decided to remove the rear plastic fender on my '06 VFR. I didn't buy a new "fender eliminator kit" but rather thought that the metal brace that is mounted under it would surfice as I would still be able to mount my liscence plate on it. My concern however is that this pre-existing metal bracket does not provide any support for the rear cowl and tail light assembly. I didn't realize that the original fender supported the tail end untill it was removed and I noticed some flexing when I put my hand down on the tail section. Is this a problem and if so do the after market "fender eliminater kits" provide the rear support needed that the factory fender apparently does. Any help would be great.
    P.S I will post a photo of this when it is done.
  2. jrj
    jrj New Member
    Calgary, Alberta
    Photo of this fender mod
    I took the metal brace that was under the plastic rear fender and sprayed it an aluminum grey to match the exposed frame work on the bike, but as mentioned above this bracket doesn't provide the support that I beleive the original plastic fender provided for the tail end of the rear cowl assembly. What do you think. If this is not the right approach than I can just buy a proper kit, if it is ok than I saved $50.
  3. Rex Redmon
    Rex Redmon New Member
    Wisconsin
    Hi Guys, Any photos to post yet I am considering either buy a kit or doing my own thing but I also maybe changing the exhaust so this maybe a larger project than just removing the fender.
  4. marc28ni
    marc28ni New Member
    Downpatrick N.Ireland
    hey when I was fittin my honda hard cases I seen the bracket, 6 bolts off give it a clean painted and refitted the back bracket looks great with my new smaller number plate. I really cant see there being any problem with it at all...
    will post pics a s a p when I get home
  5. tmausti
    tmausti New Member
    Arkansas
    Tail fender
    I took the plastic fender off and cut it down, relocated the light, and sanded down the edge to give it the factory look. This allowed me to get rid of the fender while maintaining the support for the tail of the bike.
  6. marc28ni
    marc28ni New Member
    Same as mine m8 saves me posting pics lol
  7. 02 VFR Rider
    02 VFR Rider New Member
