rear break leaver adj???
Discussion in 'General VFR Discussions' started by tweber, Jun 28, 2007.
  1. tweber
    tweber New Member
    NC
    Hello All,
    New to Forum, great information on the VFR. My issue; Had my 95 for about 1 month love the bike, I've notice that my rear break leaver has a lot more travel than when i first started riding. I'm not slamming or over braking, the rear brake does grab but i have to press down more than before. Is there an adjustment that can be made or do I need new pads already? the fronts are working fine. Checked brake fluid all levels within spec.
  2. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    check the fluid level in the rear resevior to make sure it isn't low, otherwise new pads would probably be a good investment. I put EBC pads on the rear of mine it takes a bit of getting used to cause the feel is a bit different, but they work great.
  3. tweber
    tweber New Member
    NC
    Hello Vinny,
    Thanks for the advice, I'll check the level as you suggest. Will let you know the results.
    Thanks,
    Thomas
