Rear brake pads
Discussion in '3rd & 4th Generation 1990-1997' started by 95VFRoverhaul, Mar 18, 2021.
  1. 95VFRoverhaul
    95VFRoverhaul New Member
    Hey guys changed my brakes on my 95 750 vfr and got a rear brake chatter when going slow. After examining some more the brake pad almost seems to short and barley catches the end slot of the opposite of the pin. I have the clip in place. was I sent the wrong pads? Or is that just how the brakes fit this bike?
    I look cool but I don’t wanna sound lame.
    Thanks homies
  2. 95VFRoverhaul
    Also front and rear brake pads are the same size correct? None of my boxes were marked in the kit but all looked identical
  3. squirrelman
    it's important to clean discs really well when installing new pads, especially if the new pads are a different brand. brake clean spray, sandpaper, green scotchbrite.
    also be sure the slider pins are well greased so caliper can move side-to-side a little.
    sometimes it helps to use a round file to slightly enlarge and smooth out the holes to remove any burrs.
    95VFRoverhaul likes this.
  4. 34468 Randy
    I don't know this for sure at all, but I doubt that the rear and the front brake pads would be the same. Far more braking power is needed on the front seeing as the weight transfers to the front when braking. Just like in a car I guess.
    But please, someone in the know correct me if I am wrong.
  5. 95VFRoverhaul
    How tight did your guys rear pads fit?
    I revived 3 boxes of the same size. 2 sets on front 1 on rear
  6. Simon Edwards
    Simon Edwards New Member
    Berkshire
    Looking at the Honda parts list:
    Front pads set: 45105ML7405
    Rear pads set: 43105MY7405
    They are indeed different. Close, but different. If you only read the last 4 digits it would be easy to make that mistake.
    Rear USA brake diagram: https://www.cmsnl.com/honda-vfr750f-1995-s-usa_model7618/partslist/F++13.html#.YJJvRKHTUUQ
    Front USA brake diagram: https://www.cmsnl.com/honda-vfr750f-1995-s-usa_model7618/partslist/F++10.html#.YJJvP6HTUUQ
    When I took mine out and refitted them recently both rear and front were a close but smooth fit lengthways. Definitely no slop lengthways.
    The USA and UK bikes have the same part numbers. Looks like they are likely to be universal parts for this model, not location-specific items. They are just not the same at both ends of the bike.
    Rear UK brake diagram: https://www.cmsnl.com/honda-vfr750f-1995-s-england_model5648/partslist/F__1300.html#.YJJpJKHTUUQ
    Front UK brake diagram: https://www.cmsnl.com/honda-vfr750f-1995-s-england_model5648/partslist/F__1000.html
    The comments by others above regarding installation advice are all good. But none of them will help you if one of those too-short pads drops down onto the hub and jams there.
    I think you need to have a word with your supplier.
  7. raYzerman
    raYzerman Member
    Millgrove, ON
    Honda typically has a thicker pad on the rear, but the fitment is the same...... thus two part numbers. Look up aftermarket, EBC for example and they say same pad front and rear.
    Be sure to push the caliper slider fully one way and they should stay in the clip.
  8. jorgescar69
    jorgescar69 New Member
    La Puente, CA, United States
    Rear are thicker... font are thinner.
