Rear brake line positioning bracket broke
Discussion in 'General VFR Discussions' started by 5string, Sep 13, 2013.
  1. 5string
    5string New Member
    Does it need replacement before riding?
  2. 5string
    5string New Member
    The wire one attached to the swingarm chain adj pinch bolt
  3. Scubalong
    Should be fine it will not go any where. You can order one and replace it. Ride on brother
  4. 5string
    5string New Member
    Thanks! Anything special during replacement, ie "do this or you are doomed"?
  5. Scubalong
    It is an easy fix you can just loosing up the bolt and take the old out and replace with the new should take about half a beer.
  6. Scubalong
    By the way make sure torque the bolt back to spec. I believe is 45flbs
    Let me check for you brb
  7. OOTV
    OOTV Member
    Close...it's 54 ftlbs.
  8. Scubalong
    Haha Ootvs come to the rescue :thumbsup:
    I remember the number but not in order :pound:
